Wireless clients getting dropped from the wireless controller 5508/air-cap2601 showing 'Limited Connection'.
Jesus Carrillo
Level 2
Level 2
I have a wireless controller 5508 with air-cap 2601 installed. Random users are getting limited connection and a simple resetting of the wireless network card brings them back online.
This is happening very often and making the local technicians frustrated. Does anyone have any suggestions please?
WLC version 7.4.121.0
Air-Cap 2601 version 7.4.121.0
Wireless client windows 7
Thanks in advanced!
Jesus
Freerk Terpstra
Level 11
Level 11
Besides the update of the WLC software, like Rasika already has recommended, also check if there are any driver updates available for the wireless clients.
If updating the software does not fix the problem, please provide us with an "show wlan xx" and try to run an "debug client MAC" while the issue occurs.
7 Replies 7
Rasika Nayanajith
Thanks for your advice. I will try that tomorrow.
Jesus
did you find a solution
Sorry for the dalay and thanks for checking back on this.
I upgraded the FUS and the firmware and the issue continued.
Later we found out that the computers needed an update to the deepfreeze software it had.
We found out that it was the deepfreeze program because we stopped the service on half of the computers using wifi and left the other half with deepfreeze running.
Next morning the half not running the deepfreeze remained with internet connectivity.
So the school technicians had to do some upgrade to the deepfreeze software.
Now all of the wifi pc's are running the deepfreeze and continue to have internet.
Thanks everybody!!
If you experience frequent drops, you might have hit the below bug.
https://tools.cisco.com/bugsearch/bug/CSCuq71068
AP traffic issue causing client to lose layer 3 connectivity
CSCuq71068
Regards.
Freerk Terpstra
Level 11
Level 11
Sure I will try that tomorrow. I have some computers that are giving me the limited connectivity and they are in the mac filter already.
Thanks!
