Wireless Compatibility Matrix
Heinz
Level 3
Level 3
Good Day,
Checking this matrix:
(For AP's compatible with WLC Firmware Version: 8.5.160.0)
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
The matrix lists AP models 1600, 2600, 2800 ect.
I am 99% sure above listed models includes AIR-CAP1602I-E-K9, AIR-CAP2602I-E-K9, AIR-AP2802I-E-K9.
Most importantly it seems WLC Firmware Version: 8.5.160.0 supports Outdoor Aironet 1562E
If anybody can confirm the compatibilities I will apricate it.
Thanks & Regards
Scott Fella
Just to add, you can drop the "2" at the end of the model.  1602 would be listed as 1600, the same for a 9130, would be 9100, etc.  The models you have listed is in the compatibility for the version of code from 8.5.103.0 all the way up to 8.5.182.0.
-Scott
balaji.bandi
as per matrix the model listed supported.
look at the bottom of the page as i see it only support until 8.3.X controller....this need to check
Note : check compatabilityu against controller also. not only with AP
BB
I had the 2802 and 1562 running on my WLC 2504 with software 8.5.171.0. Yes, they work. I didn't have the 1600 and 2600 running with 8.5, but at least they are listed in the Matrix *and* the release notes.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
Scott Fella
-Scott
Thank you for the reply / info
