Wireless Connection issues
alex-cooney
Community Member
Site with a 3 months old Cisco Catalyst 9800-L Wireless Controller installed, S/W version 17.9.5. Using 10 x CW9162I-Z Access Points, 3 SSIDs using 2.4 & 5GHz range
Since installation, most devices will need multiple attempts to connect to wifi. Enter password, will just come back & say some variation of 'Could Not Connect'. After trying anywhere from 3-10 times, it will eventually connect & will work fine after that.
Happens on computers (Windows & Mac), phones, tablets, on multiple Access Points. Most of the troubleshooting I can find relates to the devices not being able to connect at all. I inherited this setup, so am not super-familiar with Ciso interfaces. Site is remote, so have not been able to get there to try power-cycling access points (or controller)
11 Replies 11
ammahend
How did you conclude this ? "Most of the troubleshooting I can find relates to the devices not being able to connect at all"
to start with not a bad idea to run config through analyzer to see if something stands out
 https://community.cisco.com/t5/wireless-mobility-knowledge-base/wlc-config-analyzer/ta-p/3119057
also run controller basic KPI checks.
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/217738-monitor-catalyst-9800-kpis-key-performa.html
More specific to the issue, you need to do a capture an over the air capture (assuming you are not encrypting management frames) , this will give more details on if the failure is at L2 if not then for higher layer you can do capture on controller itself (assuming you are centralized).  follow this document for capture, reproduce the issue and share the capture as well as radio active trace for the client .
https://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-mobility/217042-collect-packet-captures-over-the-air-on.html
-hope this helps-
Ammahend, I will look into these, but it's starting to get outside of my knowledge base.
Leo Laohoo
Reboot the APs.
Thanks Leo. Probably a silly question - will this one restart, or reset (wipe), the AP? I know a lot of places use these words interchangeably, so never sure which way it will go!
That will reload the AP @alex-cooney
On CLI: ap name <ap-name> reset
And to do a CAPWAP restart (without reloading): ap name <ap-name> reset capwap
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
TTA
Community Member
Rich,
Thanks for that. Sorry to probably ask the obvious, but I am looking to just restart the AP (same as turning it off & back on) rather than wipe the configuration.
From what I can see, the command ap name <ap-name> reset will wipe the config, rather than just restart the AP? Someone mentioned the ap boot command, but that doesn't seem to be an option in ssh/cli
No problem - that's why I said it will reload the AP (reload in Cisco speak is reboot) - normally the same as power cycling the box.  A CAPWAP restart does not reload the device - it just re-initialises the CAPWAP connection to the controller and will then pick up new settings etc (and clear some bugs).
Wiping the config = factory default reset which is a different command.
9800#clear ap config <apname> ?
chassis Chassis
eventlog Clear the event log contents on Cisco AP(s)
keep-ip-config Do not erase the static IP configuration of the Cisco AP
<cr> <cr>
Mark Elsen
 - Start with a checkup of the 9800-L controller's configuration using the CLI command show tech wireless
   (not 'show tech' )and feed the output from that into Wireless Config Analyzer
   + Use full client debugging for problematic clients according to https://logadvisor.cisco.com/logadvisor/wireless/9800/9800ClientConnectivity , these debugs can be analyzed with Wireless Debug Analyzer
  +    Outputs from the commands mentioned in https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/217738-monitor-catalyst-9800-kpis-key-performa.html#anc5  may also help to get additional insights
 + Since 17.9.x is now EOL , consider upgrading to 17.12.3 (latest advisory)
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
JPavonM
- Check how it looks like by setting your production SSID to only broadcast in one band (I have seen some devices continuosly roaming between bands during negotiation)
- Disable vendor features like band select or load balance in the WLAN settings.
- If using fast roaming disable it to see how it looks like (802.11r).
- Check how it looks like by lowering the security settings. (If you are using WPA3 like features, disable them: wpa3, dot11w, sha-256)
- Check your devices have the latest OS patches and wNIC drivers.
- Check there is no radio interference in the channels your APs are operating. (even check for DFS events in the vicinity)
- Less probable but still possible, check you're not impacted by a DoS attacks llike deauth or disassociation floods. (perform a packet capture in some channels your APs are operating and look for tons of these packets)
Rich R
As already mentioned you should seriously consider upgrading the software version as per TAC recommended list (below).
How is your WLAN configured?
What authentication is it using?
What you're describing can also be a symptom of misconfigured radius CoA so the CoA from radius server cannot update the WLC on client authentication status dynamically.
TTA
Community Member
We've managed to get a remote restart of the AP done, & so far it seems stable. Will test it over the next few days, & come back if problems persist. Thanks for all the advice
