Showing results forĀ
Search instead forĀ
Did you mean:Ā
Wireless Controller 2504 SNTP / NTP Errors
enewburn1
Level 3
Level 3
I have a 2504 running 8.1.102.0 for some reason it is constantly generating a SNTP error that it is unable to send a NTP packet. It appears to be trying to send this to an all IPv6 address of "::"
I have disabled ipv6 on the Controller under global policy, wiped out my NTP servers and re configured as well as rebooted the controller.
Still the rrors persist - even if I wipe out ALL NTP servers and just go with local time
Any thoughts?
5 Replies 5
Leo Laohoo
Post the output to the command "sh ipv6 summary".
show ipv6 summ
Global Config............................... Disabled
Reachable-lifetime value.................... 300
Stale-lifetime value........................ 86400
Down-lifetime value......................... 30
RA Throttling............................... Disabled
RA Throttling allow at-least................ 1
RA Throttling allow at-most................. 1
RA Throttling max-through................... 10
RA Throttling throttle-period............... 600
RA Throttling interval-option............... passthrough
NS Mulitcast CacheMiss Forwarding........... Disabled
NA Mulitcast Forwarding..................... Enabled
IPv6 Capwap UDP Lite........................ Enabled
Operating System IPv6 state ................ Disabled
Could be a bug.  Try using 8.1.131.0.
I've upgraded the Controller and APs to 8.1.131.0 (which was a good learning experience.) Unfortunately I still have the error
Ok, how about issue the command "sh time"?
