Wireless Controller 2504 with CAP1702i
alokkumarmaity1
I have installed and configure Cisco 2504 wireless controller. Also attached a AP(AIR-CAP1702i) in PoE port. But it's not showing in controller and also not showing SSID.
Please suggest.
Alok kr. maity
Leo Laohoo
Post the complete output to the following commands:
1.  WLC:  sh sysinfo;
2.  WLC:  sh time;
3.  AP:  sh version;
4.  AP:  sh ip interface brief
Abhishek Abhishek
 Searching WLANs
You can search for specific WLANs in the list of up to 512 WLANs on the WLANs page. This feature is especially useful if your WLANs span multiple pages, preventing you from viewing them all at once.
To search for WLANs using the controller GUI, follow these steps"
Step 1 On the WLANs page, click Change Filter. The Search WLANs dialog box appears (see Figure 7-4).
Figure 7-4 Search WLANs Dialog Box
Step 2 Perform one of the following:
•To search for WLANs based on profile name, select the Profile Name check box and enter the desired profile name in the edit box.
•To search for WLANs based on SSID, select the SSID check box and enter the desired SSID in the edit box.
•To search for WLANs based on their status, select the Status check box and choose Enabled or Disabled from the drop-down list.
Step 3 Click Find. Only the WLANs that match your search criteria appear on the WLANs page, and the Current Filter field at the top of the page specifies the search criteria used to generate the list (for example, None, Profile Name:user1, SSID:test1, Status:disabled).
Note To clear any configured search criteria and display the entire list of WLANs, click Clear Filter.
