Wireless Controller 3504
Sally Onsy
Frequent Visitor
Frequent Visitor
Kindly I am designing for customer with wireless controller 3504 and 30 Access Points of Model AIR-AP3802I-I-K9.
The customer has infrastructure switching using switches POE other than cisco switches (all switches are HP).
Please need help to check if there is any constrains of using LWAPP protocol through HP switches?
Is there any recommendation for specific protocols needed in the switching layer to allow the communication between the controller &  APs?
Thank You
Sally
4 Accepted Solutions
Hi @Sally Onsy
Not really same protocolos and port are use on HP switches UDP 5246 and 5247, for a straight implementatión be sure that APs and the WLC are on the same subnet.
Espero que la información haya sido útil y si no tienes más preguntas recuerda cerrar el topic, seleccionando la respuesta como "Respuesta correcta"
**Please rate the answer if this information was useful***
**Por favor si la información fue util marca esta respuesta como correcta**
*Tu reconocimiento nos alienta a seguir participando en los foros *
Cristian Matei
    In the path between AP and WLC, switches will switch the LWAPP/CAPWAP packets (they care about layer 2 destination MAC address), routers will route the LWAPP/CAPWAP packets (they care about layer 3 destination MAC address). So what can break the connectivity is a layer 3 device (router/firewall) doing some packet filtering or NAT, or an inspection device (inline) performing some layer 7 inspection or decryption.
    So if you have just switches and basic touring, i don't see a problem.
Cristian Matei.
Rasika Nayanajith
If switches are POE (IEEE802.3af), then you will face issue as 3802 AP require PoE+(IEEE802.3at)
For CAPWAP, you only require simple IP connectivity from AP to WLC, that's all
Rasika
*** Pls rate all useful responses ***
Leo Laohoo
Do the HP switches support CDP or LLDP?
How much power can each port of the switch support? If it can't support 30.0w PoE (per port) then don't bother.
Hi @Sally Onsy
Cristian Matei
Cristian Matei.
Rasika Nayanajith
Rasika
Leo Laohoo
