Wireless Controller 4400 upgrade problem
samuelwai
Community Member
Hi all :
I want to know whether i can enter a license key to Wireless controller to increase the AP Quantity of 4400 controller ? As I bought a 4400 controller support 50 AP , and now i want to add AP to the controller more than 50 AP .
Rob Huffman
Hi Samuel,
You won't love this answer but, the number of supported AP's on a WLC is based on the Hardware configuration and cannot be changed. You will need to purchase a second WLC. The upside is you will be able to add some redundancy to your deployment 🙂
\\The limitation on the number of supported access points is based on the hardware that you have. The 4402 WLC with two gigabit Ethernet ports comes in configurations that support 12, 25, and 50 access points. The 4404 WLC with four gigabit Ethernet ports supports 100 access points.
AIR-WLC4402-12-K9
4400 Series WLAN Controller for up to 12 Cisco access points
AIR-WLC4402-25-K9
4400 Series WLAN Controller for up to 25 Cisco access points
AIR-WLC4402-50-K9
4400 Series WLAN Controller for up to 50 Cisco access points
AIR-WLC4404-100-K9
4400 Series WLAN Controller for up to 100 Cisco access points
http://www.cisco.com/en/US/prod/collateral/wireless/ps6302/ps8322/ps6307/product_data_sheet0900aecd802570b0_ps6366_Products_Data_Sheet.html
Hope this helps!
Rob
Hi Rob :
Really thanks for your help and answer. I got it and i will suggest my customer to buy a new one .
Thanks a lot!
