Wireless controller 5500 certificate
jcdickert
Community Member
I have a Cisco 5500 wireless controller that I was having problems reaching the Webadmin portal through HTTPS.  I followed some instruction to enable HTTP then delete and regenerate the certificate.  When I did this, none of my APs will connect any longer.  Any ideas on how to resolve this?  This is urgent.  This is a K-12 school with a 1:1 program so without WiFi, classes are at a stand still tomorrow.
Thanks!
Jim
Mark Elsen
 - Can you post an ap boot process , also check the controller-logs when an ap tries to connect , as far as urgency is concerned this forum is users-based  , not Cisco. Check this thread : https://community.cisco.com/t5/switching/support/td-p/4695696
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Rich R
I'm willing to bet you've hit the expired certs problem - same as many others in last few months! So here we go again ...
Read this field notice through very carefully (twice if necessary) then follow all the instructions carefully in the right order:
https://www.cisco.com/c/en/us/support/docs/field-notices/639/fn63942.html
I'll summarise it for the umpteenth time:
1. Upgrade to latest version which supports your APs and WLC - probably 8.5.182.0 (assuming you mean 5508)
https://www.cisco.com/c/en/us/support/docs/wireless/wireless-lan-controller-software/200046-tac-recommended-aireos.html#anc10
2. Apply the config workaround on the WLC
3. Disable NTP and set time manually to before your certs expired
4. Allow all the APs to join, download new code, pick up the config workaround
5 Re-enable NTP
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
