WLC 9800-40 Click to Accept Webpage
scottsassin
We have an open wireless network, with no security.
We want to implement a Click-to-Accept page, when a client connects. Once the client clicks the accept button, we want them to be redirected to a website.
Can you check your config:
Configuration > Security > Web Auth > global
make sure you set the Virtual IPv4 Address "for example 192.0.2.1"
and you can create another Parameter Map and select Type = consent and any other options
after that, go to Configuration > Tags & Profiles > WLANs
Click on your SSID
go to Security > Layer 2 = none
Layer 3 Web Policy checked
WebAuth Parameter map = select the one you created with consent
a few notes:
Code prior 17.3:
If you limit the GUI Admin access to just https this will cause problems for the WebAuth, meaning, if we have:
no ip http server
ip http secure-server
then the http access for WebAuth will not accept http traffic only https,
Most today’s client’s devices (Smartphones or PCs) have a way to check that using their hidden websites to check connectivity, for example, Apple iPhone will check with Apple website dedicated for this purpose (http://captive.apple.com/hotspot-detect.html) to present to the user the login portal (AUP portal), same thing for Firefox, (http://detectportal.firefox.com/success.txt) this is done by http traffic, and if you disabled that as in above then you will not see a popup window.
17.3 code and after:
Starting from 17.3.1 we have new cli commands to enable/disable http/https on the WebAuth, this was listed here in the release notes:
https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/17-3/release-notes/rn-17-3-9800.html
we can have that http to Admin (Device Management) disabled and we can enable http if we want to the WebAuth using:
webauth-http-enable
from the "global" parameter map.
6 Replies 6
Rasika Nayanajith
Pls see below document, that will help you to set it up
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/213923-configure-a-web-authentication-ssid-on-c.html
Rasika
*** Pls rate all useful responses ***
I followed the document, but can't seem to have the web page pop up, upon connecting.
Click on your SSID
a few notes:
Code prior 17.3:
no ip http server
webauth-http-enable
Thank you for the very useful configurations. I have configured as directed and all my devices EXCEPT iPhones appear to be working as expected. Is there a special configuration for iPhones or Apple devices in general?
For my iPhone, upon selecting the SSID, there is no pop-up page. I have to go to my browser and try to get on the Internet, at that point I'm redirected to the portal page.
Has anybody experienced this? Can anyone help?
Check if you have "Captive Bypass Portal" enabled or checked in the parameter map, if it's unchecked then let me ask you, is this with ISE 3.1? if so, just install patch 3 or 4 because it has a fix for that.
doyejide1
Thank you. Unchecking "Captive Bypass Portal" fixed it. We are on ISE 3.1 patch 3.
