wireless controller 5500
dkblee
Level 7
Level 7
hi! do the wireless controller 5500 and the cisco AP have the feature to allow access to an SSID only if the client's MAC or IP or name is registered with the system?
dancampb
Level 11
Level 11
Sure, you could setup mac authentication or machine only authentication.  It depends on the rest of your network setup and size to which would be a better choice.
