Wireless Controller 5508 using 3702I and 1131ag
pcmaster112
Hi Team,
I have a couple of questions:
  1) I have a Cisco 5508 WLC running 8.0.140.0 code that I'm running with mix with 3702I and 1131ag AP's. I need help to find the most stable firmware for the AP running lightweight.
2) I have a Cisco WLC running 8.0.140.0 code with 10 Cisco 3702i access point running lightweight. Whats the most stable code to use.
Note: Both of these controllers are going into a customer home.
balaji.bandi
i would suggest to read the Upgrade Guide  and release notes of the version and feature you looking to deploy in your enviroment.,
https://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/68835-wlc-upgrade.html
you need to Look the features support along with AP support - they have highligheted based on the relase notes, read carerfully.
i would suggest 8.5X stable version, but i do not belive they do support 1131 AP.
Look at the matrix :
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
BB
Rasika Nayanajith
1. Go with 8.0.152.0 release
2. Go with 8.5.164.0 release
Here are the release notes, pls check those first prior to any upgrades
https://www.cisco.com/c/en/us/support/wireless/wireless-lan-controller-software/products-release-notes-list.html
Rasika
*** Pls rate all useful responses ***
Leo Laohoo
IF there is only one WLC, then stick with the latest 8.0.X.X train.
