09-04-2020 02:52 AM - edited 07-05-2021 12:28 PM
WLC 5520 and ISE
i got a question, in case of central authentication 802.1x with ISE, and the WLC is failed is there a method to configure the flexconnect AP to continue to authenticate new users that would access the network using the Radius server.
thanks
09-04-2020 03:12 AM
09-04-2020 03:22 AM
thanks for your reply
the radius server is reachable for the Access Point.
ISE(radius) : UP
WLC: down
Flexconnect AP can reach ISE.
in this case how to configure a Flexconnect Access point to authenticate new users?
thanks
09-04-2020 03:21 AM
Any new or re-auth fails , so better to have redundency in place
09-04-2020 03:46 AM
Thanks for your reply
so if I understood you well, you mean that in case of WLC failure, we lose the ability to re-auth or authenticate new users with 802.1x, even when, we are using a flexconnect .
as is mentioned in the link below , it's possible to authenticate 802.1x new users when WLC is down:
best regards
09-04-2020 07:30 AM
09-04-2020 08:07 AM
so how to configure flexconnect access point to authenticate or re-auth 802.1x users via a local backup radius server.
note : WLC is down
09-04-2020 11:25 AM
09-04-2020 05:38 AM
best regards
