Wireless Controller 8510 - Adding Licenses
dvaggalis
Level 3
Level 3
Is their an End of Sale date for purchasing adder licenses for the 8510 Controller?
i see the L-LIC-CT8500-1A license can still be ordered, but why can't you order the L-LIC-CT8500-100A?
jagan.chowdam
You should use the Top-Level SKU L-LIC-CT8500-UPG and then under this you'll be able to add the adder license L-LIC-CT8500-1A or L-LIC-CT8500-100A. The licenses are still orderable from Cisco Configuration Tool.
Please rate all helpful responses.
Sandeep Choudhary
you should be able to buy it but just try to contact to your local supplier, he/she may help you .
Dont forget to arte helpful posts
jagan.chowdam
dvaggalis
Level 3
Level 3
Shoot, what's the difference between L-LIC-CT8500-SP-1A  and L-LIC-CT8500-1A?
