wireless controller authentication
ronshuster
Level 5
Level 5
We have a wireless controller and a number of AP's connecting to it over a routable private wan.
Using a central Radius server we authenticate all wireless users, however there are a number of remote sites which we prefer to use a local Radius server for authentication.
Looking at the GUI, it looks like the Radius server field is global to ALL ap's, is there a way to force specific IP's to authenticate on other Radius servers?
Serge Yasmine
Hi, yes, you can do this with HREAP groups. You need to make sure remote APs are in HREAP mode and then add them to the group you create and map them to the desired Radius Server.
--> WLC WEB GUI --> Wireless --> HREAP Groups
