Wireless Controller, clients in VLAN1
steven.vandyk
I have a network, everything in VLAN1 (I know this is not good, but for the moment, I like to keep it that way) I installed a WLC 4402, but I cant seem to get my wireless clients in the same VLAN as the controller. Is this normal? Is there a way around? Thank You
alex.hoang
Community Member
I have done this without any issues in a flat network. You do not need to create any new interfaces since it is flat. In your wireless lan SSID, use the management interface as its interface. If the VLAN is flat, make sure the VLAN identifier is 0. Hope this helps.
alex.hoang
Community Member
Yes this works. Thx
