Wireless controller ports
ahmedtallat
Visitor
Hi We are going to buy wireless controller 5760 As we know it's have 6 SFP ports Can we use this ports to connect 10G or 1G ? How many ports required to connect if we have to manage 150 access point ? Thank you
Table 2 says yes.
And you can also check this table. You will see SFP modules supported.
http://www.cisco.com/c/en/us/td/docs/wireless/controller/5700/install/guide/ctrl5760.html
Espero que la información haya sido útil y si no tienes más preguntas recuerda cerrar el topic, seleccionando la respuesta como "Respuesta correcta"
**Please rate the answer if this information was useful***
**Por favor si la información fue util marca esta respuesta como correcta**
Hi.
Yes you can use 10G SFP.
http://www.cisco.com/c/en/us/products/collateral/wireless/5700-series-wireless-lan-controllers/data_sheet_c78-722607.html
The main deal is what applications will you use in your WLAN and what protocol you will use. a/b/g/n/ac ?
10 GB is a good port but you can use too LAG 🙂
Thank you for help
yes we are going to use a/b/g/n in the network but we still not have 10G ports in the switches
So if possible to use for now 4 ports as 1G and make them LAG
after we have the 10G in the switch will change only the SEP with SEP+ and no change in the controller, is this possible
Table 2 says yes.
