wireless controller system software .aes (6500 WISM)
haibo li
Community Member
hi,
i am looking around how  to copy system software .aes to tftp server . and ram installed in WLC of 6500 wism ?
try looking any command, i want to copy WLC software to tftp server .  Because  My WLC software version can not be found in the Cisco official website
thanks..
--------------Show udi---------------
NAME: "Chassis"    , DESCR: "Cisco Wireless Controller"
PID: WS-SVC-WISM-1-K9,  VID: V01,  SN: FAS120906VL
---------------Show sysinfo---------------
System Information
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 6.0.199.157
RTOS Version..................................... 6.0.199.157
Bootloader Version............................... 4.0.219.0
Emergency Image Version.......................... N/A
Build Type....................................... DATA + WPS
System Name...................................... gangtie-2
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.14179.1.1.4.4
IP Address....................................... 10.107.74.60
System Up Time................................... 59 days 19 hrs 36 mins 12 secs
System Timezone Location.........................
--More-- or (q)uit%   I
.................. 5168172 Secs
erhead bytes)
ar 13 10:09:27.916: %APF-6-MOBILE_NOT_EXCLUDED: apf_ms.c:3785 Could not exclude the mobile 00:50:f6:2d:85:8b.
Configured Country............................... CN  - China
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +42 C
State of 802.11b Network......................... Disabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 1
3rd Party Access Point Support................... Disabled
Number of Active Clients......................... 224
Burned-in MAC Address............................ 00:1E:F7:D6:FE:E0
Maximum number of APs supported.................. 150
---------------Show Interface ---------------
Interface Configuration
Interface Name................................... ap-manager
MAC Address...................................... 00:1e:f7:d6:fe:eb
IP Address....................................... 10.107.76.8
IP Netmask....................................... 255.255.248.0
IP Gateway....................................... 10.107.76.1
--More-- or (q)uit
External NAT IP State............................ Disabled
External NAT IP Address.......................... 0.0.0.0
VLAN............................................. untagged
Active Physical Port............................. LAG (29)
Primary Physical Port............................ LAG (29)
Backup Physical Port............................. Unconfigured
Primary DHCP Server.............................. 10.107.76.1
Secondary DHCP Server............................ Unconfigured
DHCP Option 82................................... Disabled
ACL.............................................. Unconfigured
AP Manager....................................... Yes
Guest Interface.................................. No
The last number is 157 !!!!!!!
Calm down.
The last number is .157 is because your file is a SPECIAL ENGINEERING FIX released by Cisco TAC on a case-to-case basis.
If you want exactly the same thing, create a Cisco TAC Case.
12 Replies 12
Leo Laohoo
WiSM-1 software can be found here.
haibo li
Community Member
S/W  Version .................................... 6.0.199.157
Boot  Version ................................... 12.4.13.0
Mini IOS Version ................................ 3.0.51.0
Stats Reporting Period .......................... 180
Primary Boot Image............................... Code 6.0.199.157
hi:
my boot image version is 6.0.199.157 ,but i can not be found in the Cisco official website.i must find it .what can i do it ?
thanks! my wlc is 6500 wism.
haibo li
Community Member
System Information
erhead bytes)
--More-- or (q)uit
Leo Laohoo
what can i do it ?
I have already posted the link where you can choose and download the file.
hi:
i can not see 6.0.199.157
You CANNOT copy the software from the WiSM to the TFTP server.  You download from the Cisco website.
Your initial question is you cannot find the file location from the Cisco website, hence, I provided the link.
I can not see this version 6.0.199.157    , can you  give  me a screenshots!  this is 157
Calm down.
thanks!
fantasy19830306
Community Member
e3200
