Wireless Controller Web Interface WLAN SSID Sorting issues
dprior
Community Member
I'm seeing a few issues with SSID sorting on the "simple" interface for the 2500 Series Wireless Controller (I assume this extends to other products as well).
In no particular order:
- Clicking the Column to Sort by WLAN SSID Doesn't work. The clients are not sorted.
- You can only see 25 or 50 clients at a time. This is a problem because the only workaround for sorting involves copy/paste into spreadsheet software.
- The "Advanced" interface doesn't show hostnames for connected clients, therefore cannot be used as a substitute for the new one.
12 Replies 12
Leo Laohoo
Are you talking about the Dashboard?
Yes, the Dashboard, clients section.
Sandeep Choudhary
Go to Monitor > Clients and then try to play with Change Filter to sort out the clinets which are connetce dwith specifi WLAN
Dont forget to rate helpful posts
When I use the Filter option, the entire client list disappears.
which software version you are using ?
did you try with anoother browser ?
Dont forget to arte helpful posts
Yes, I've tried chrome and safari, possibly even others. Very clearly sorting by SSID does not work. Filtering by SSID doesn't work either.
Software Version 8.2.164.0. Cisco 2500 Series Wireless Controller
What are you trying to see, the filter option in 2504 works for me with no issues.
I would recommend for you to upgrade to the latest on 8.2 which is 8.2.166.0.
Please do try to upgrade also your browser or use internet explorer.
Also as an advise, by upgrading your wlc to 8.2.166.0 you will be avoiding this nasty bug
CSCvf52723
Let me know if it works.
-Rodrigo Osorio Porras
What are you trying to see in the filter option?   2504 works for me with no issues.
CSCvf52723
dprior
Community Member
when you click on the WLAN SSID Column, does it sort the list properly?
What I do is:
go to monitor tab
Select clients
Click on change filter
only selec "WLAN SSID" checkbox and select the ssid I want to see.
Click apply.
and it only shows me the clients on that ssid.
Is this what you want?
dprior
Community Member
uploaded gif of behavior
I see.
Are you using a mobility express solution?
Could you tell me the model of WLC you are using?
You can see this with "show inventory"
I have not test this on ME if that is the case.
Once you provide this I can test and let you know.
