Wireless Controller
richprime890
Frequent Visitor
Frequent Visitor
Hi all, new here, am deploying a wireless network using the Cisco WLC series 9800 and APs, APs have successfully joined the controller but the SSIDs i created are not been broadcasted from the APs. Have anyone face this challenge before kindly advise.
balaji.bandi
what is the IOS XE code running on the device - upgrade to latest 17.9.4a for stability, what model of AP
based on experience below need to check :
  •  Ensure your AP get sufficient PoE power
  • NTP
  • Verify that Country on WLC code matches with the AP model number.
  • 802.11b/g/n and 802.11 a/n/ac are enabled under wireless.
  • Check AP Profiles.
  • SSID is in enabled state.
  • SSID is being broadcasted.
BB
5 Replies 5
balaji.bandi
  • NTP
BB
Mark Elsen
 - Have  a checkup of your  9800 WLC configuration with the CLI command show tech wireless and feed the output to : Wireless Config Analyzer
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Mark Elsen
 - Added reply : also use the CLI command  wireless config validate
 M.
j.reichert
Frequent Visitor
Frequent Visitor
Make sure your SSID's are added to the policy tag you are using for these APs. Are you using more than one policy tag or just the default?
