Wireless deployment
Cisco-User500
We are in the process of evaluating Cisco wireless controllers and AP. We have 3602 APs and 2504 controllers right now. We have mutliple branch offices connected to the main office through layer 3 and they all have different vtp domains and vlans. I am trying to deploy APs at the branch offices and connect them back to the controller and the central site. I created a sub interface and ssid with one of the vlans at the branch office on the controller and was able to get the AP to join the controller through DNS. However, a client at the branch office connected to the AP was unable to ping anything at the branch and central sites.
does anyone has any documentations on how to deploy such a setup where the controller is at the central site and AP at the branch office going through mutiple routers in between?
nikhilcherian
Level 8
Level 8
If you have a local DHCP server in each of the branch locations, you should go for the HREAP solutions
https://supportforums.cisco.com/message/3419018#3419018
The client in your branch location may be getting IP address from the central location. If that subnet is not routed to the branch locations, you will not be able to ping the branch devices
Try to configure HREAP with local -switching
NikhiL
