wireless design options
Khawar Khan
Community Member
We have centralized WLCs in datacentre to which all APs in campus associate.
The VLANs in DC are different from the ones in campus (VLANs don't extend).
There is a requirement in one lab (currently 2 APs) where the wireless users should be on the same VLAN as wired desktops. The wireless devices need to access application running on the desktop and protocol uses broadcast in the same VLAN to discover desktops running the application.
I am thinking about few options and would like to know what you think about it:
1) use centralized controller:
-create new SSID with PSK (just to be used in lab)
-create new AP group and add existing SSIDs along with new one
-have this new AP group on APs in lab
Problem: wireless users will be on different VLAN than desktops (VLANs don't extend between campus and DC)
2) deploy new local controller (wlc 2504)
-configure it to have same SSID's as centralized WLCs with additional SSID just for lab
-the APs in lab associate to it
-configure new SSID to use same VLAN as used by desktops in that lab
3) same as option 2 instead use ios switch 3650 as local controller
-not sure about it since i have never used ios switches to serve as controllers
4) use autonomous AP's in lab
-create new SSID just for lab
-link new SSID to vlan used by desktops
Problem: will lose other SSIDs (wireless networks - employee and guest networks).
I am more in favor of option 2 (wlc 2504 as a local controller).
Please let me know which option you will pick and why. If you would do it some other way, please state it as well. Do you see any issues with above options which i have overlooked ?
2 Accepted Solutions
Rasika Nayanajith
Why not converting those two AP as "FlexConnect" & terminate traffic locally for a given SSID & put them on to  the same VLAN of wired device ?
Rasika
-AP will switch and authenticate locally for the new SSID and remaining SSIDs will still use central resources (switch and authenticate via centralized WLC as before) ?
Yes, that is the way.
currently switch interface to AP is access, after converting APs to flexconnect the port will be trunk ?
Yes, AP management should be on the native vlan of this trunk link. Pls refer below reference guides for more understanding
http://www.cisco.com/c/en/us/td/docs/wireless/controller/8-1/Enterprise-Mobility-8-1-Design-Guide/Enterprise_Mobility_8-1_Deployment_Guide/ch7_HREA.html
https://supportforums.cisco.com/document/98646/wireless-lan-flexconnect-configuration-example
Rasika
*** Pls rate all useful responses ***
8 Replies 8
Rasika Nayanajith
Rasika
Thanks Rasika for the quick reply.
Few questions in regards to flexconnect:
Those 2 APs in lab will have other SSIDs as well (employee, guest etc.)
-currently switch interface to AP is access, after converting APs to flexconnect the port will be trunk ?
For example, the new config will look like below ?
new SSiD = lab
desktop vlan = 101
AP vlan = 100
interface x
description Access Point x
switchport trunk native vlan 100
switchport trunk allowed vlan 100,101
switchport mode trunk
spanning-tree portfast
-can AP and clients (connecting to this new SSID) get IP address from same old central DHCP server in DC ?
cheers
Rasika
Thanks Rasika for your assistance. I tested flexconnect yesterday in my lab and it worked, will soon run POC with client and see how it goes.
Thank you so much!
cheers
Great to hear.
See, we have saved some $$ for you 😉
Let us know how your POC goes with FlexConnect option
Rasika
you surely did, let me know when you're in Sydney and i will take you to lunch/dinner 🙂
BTW, will flexconnect solution suit whole building as well ? or it's recommended for a location where there are small number of APs and for more Local Controller option is best ?
Cheers
Will do 😉
If you come down to Melbourne for Ciscolive 2017 let me know. We can meet up.
From the design point of view, FlexConnect solution developed by Cisco for customers who has a large number of branch sites (where they do not want to deploy WLC at each site) and connected to HQ over the WAN.  Since traffic locally terminating at the branch & can survive even during a  WAN link failure, this is a big advantage for such customers.
Here are basic design guidelines for FlexConnect
Pls go through this Ciscolive presentation as it will cover what features available & what limitations as of today. You can freely register for ciscolive365 if you currently not registered.
https://www.ciscolive.com/online/connect/sessionDetail.ww?SESSION_ID=90745
In a campus network, if you have 1Gbps or higher building interconnection, I would prefer local mode AP unless you have specific requirement to terminate traffic at a local switch (like what you have at the moment)
Rasika
Thanks Rasika for all your help with this. I will read the document and watch video.
Sure, i will let you know if my manager send me again to ciscolive 😛
