Wireless Design Question
support
Community Member
I am a CCNA supporting a few offices that have VPN connections through local ISP to a central site. I have one site that is remote and unable to get a broadband connection. It is aprox. 1.5 miles from a site that has a broadband connection. I wouls like to set up a wireless connection. Because of the topology I think I would need a bridge between the sites most likely on a tower. I am thinking that I would need a bridge at the remote site a bridge in the middle and a bridge at the wired office.Am I on the right track . Can this be done and what sort of antennae woud I need. Please email me at [email protected]. Thnak you
rais
Level 11
Level 11
I don't see a point in putting a bridge in the middle. Hardware/Technology is available to cover 1.5 miles.
However, if you can manage a bridge in the middle and your hardware specs support the design, go for it.
Thanks.
chloi
Level 2
Level 2
the cisco yagi antenna (AIR-ANT1949) should be able to solve your problem. you need one bridge at your wired office and one bridge at the remote site.
