Wireless DHCP
nicholas.vanbussel
Community Member
Hi, I am trying to get my 870 router to assign DHCP addresses to wireless clients. The wired LAN works fine. If I assign a static address to my laptop it seems to work fine. Just not DHCP.
I have posted my config.....
Any comments appreciated
Stephen Rodriguez
Nicholas, the problem I see is that you are using a second vlan, and you do not have it defined in the router. Try this:
interface Dot11Radio0
no ip address
encryption vlan 2 mode ciphers tkip
ssid Home
vlan 2
authentication open
authentication key-management wpa
wpa-psk ascii xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
54.0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan2
description Wireless
no ip address
bridge-group 1
interface BVI1
ip address 10.252.12.1 255.255.255.0
ip nat inside
ip virtual-reassembly
Added a VLAN2 interface that is in bridge group 1, and set the SSID to be in vlan 2, also changed the encryption command to encrypt vlan 2.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
akbar1
Community Member
In the conf mode on router run the is helper command & give the ip address of the dhcp server.
zhenningx
Level 8
Level 8
You should remove "ip nat inside" from vlan 1 config and put "bridge-group 1" under vlan 1 config.
