Wireless E&M
chris.cox
Community Member
I have two PBXs in two buildings about 100 yards from each other with a good line of sight. How can I link the two phone systems using a radio solution. Ther are only 16 users at the smaller of the two buildings.
What is the best technology?
bstremp
Level 7
Level 7
The use of WLAN 802.11b bridges can provide network connectivity up to a data rate of 33Mbps. This will require 3 antenna and bridges per side. The bridge can tie into a switch to provide an Ethernet connection to your PBX’s (as long as there is Ethernet support on your PBX).
ED CARMODY
Level 5
Level 5
Why not install telco T-1 radios? They present native T-1 interfaces that will likely connect directly to your PBXs, with no VoIP, gateways, etc.
Very straightforward, clean solution.
