Wireless equipment help
rhltechie
Level 5
Level 5
Hi All,
I have a small site that needs wireless access and a router. I am uncertain if I should use the 851 router with integrated wifi or go with a router and a separate 1130 access point. any suggestions on how I should choose?
TIA,
R
robert.wright
Level 5
Level 5
Good afternoon,
Likly you have an idea of where your router is going to be placed... Maybe in a designated rack/room/table etc. Well that location may not be best suited for the job or for RF... IE if your 'computer room' is in one corner of the building and your users are in the opposite corner, you may not have the best coverage or any coverage at all... You will then end up either buying another AP or running a series of network cables to your router.
Likly your best bet is to go with 2 devices as to be more flexable.
