Wireless Guest Auto-Anchor to Guest WLC
fatalXerror
Level 7
Level 7
Hi guys,
In my wireless design for corporate users is using Central Auth Local Switching and now I need to incorporate a Guest wireless use case using the same platform. Can I deploy another WLC to be the Anchor from the corporate WLC even though the AP is set to Local Switching or this Local Switching is set per SSID? THanks
@fatalXerror
 Per SSID. And the mobility anchor tunnel is also per SSID.
AirOS: 5508/5520, etc
If you check the "flexconnect local switching" or not is what will define the traffic hand off.
IOS-XE: 9800
