Wireless Guest Net
ppellettiere
Level 3
Level 3
We are running a 4400 - Version 4.2.176 for our guest network.
My question is Does the Web authentication/Login  page have to
be  secure https? Can it be http?
I just tested that in my lab and you need to enable http and disable https on the management http-https configuration tab.  I had to reboot the WLC in order for it to work, but that might be because I also regenerated the certificate.
-Scott
6 Replies 6
Sebastian Helmer
Level 10
Level 10
I would say it is possible, I found an idea here:
If you have HTTPS enabled on the controller the webauth login page  should use SSL.  Just go under Management - HTTP and make sure you have  HTTPS enabled.  If you don't have it enable the webauth page would not  be encrypted.
https://supportforums.cisco.com/message/3121202#3121202
regards,
Sebastian
Sorry that didn't work I still have to use https...
maybe my mistake, do you have http also enabled?
my post was just an example for the other case, to just https in case of http..
- Sebastian
-Scott
I will try this after hours in case I have to re-boot.
That Worked Thank You.
