Wireless headset for Cisco IP 7900 Series
tommyjon123
Does anyork for my Cisco IP 7900 series telephone.  I have been loork for my phone prefereably a cordless headset.  I would like either a Plantronics or a GN Netcom / Jabra,  I have been looking at the new Plantronics CS540 wireless headset but not sure ifthey work with Ciscp IP telephones.
6 Replies 6
migilles
Do you havea wired or wireless 7900 series phone?
Would assume you are referring to a wired 7900 series phone, but then again, this is the VoWLAN forum.
The 7925G, 7925G-EX and 7926G are Bluetooth 2.0 capable.
If you have a 7921G or want to use the wired 2.5 mm 3 band / 4 conductor connector, then you will need to get the Platronics quick disconnect adapter for 792x phones.
Some accessory info in the 792x Deployment Guides.
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7921g/6_0/english/deployment/guide/7921dply.pdf
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7925g/7_0/english/deployment/guide/7925dply.pdf
More info below.
http://www.headset-plus.com/office-headsets-cisco-headsets-c-2_11.html
dariusz.lipka
Cisco is selling Jawbone Icon bluetooth headsets.
http://www.cisco.com/en/US/products/ps11204/index.html
These are very nice and intelligent devices with extra features.
You can switch between devices with ease, like speak using iPhone,
then use IP phone as well without any problems.
Device is expensive, but on eBay you can grab a bargain...
ritesh.tandon
Jabra has wide range of headset which includes Blue Tooth Devices
Try link www.jabra.com/cisco for wide choice as per your need
Yungi Chu
There are many Cisco 7900 compatible wireless headsets from Plantronics and Jabra, All the information you need is here:
http://headsetplus.com/category99_105/index.html
I'd recommend the Plantronics CS540, W740, Jabra 9450, or Jabra 920.  Just to name a few.
Below is Cisco Compatibility Document from Jabra. It has list of all Cisco hardphones and softphones with info on wireless and wired headsets
http://www.jabra.com/~/media/Documentation/Strategic%20Alliances/Cisco/Cisco%20Compatibility%20Guides/BR_CompCisco_50091_V09_1310.pdf
abwahid
Level 4
Level 4
Check, jabra 9400 Series wireless headset for Cisco 7900 Series IP phone.
