01-21-2011 02:03 AM - edited 07-03-2021 07:42 PM
Dear all,
I would very much appreciate if someone could assist me with my HomeLab setup. Currently, I have ordered one Cisco 871W wireless device and looking forward to other network component/s that support Cisco 871W to create a complete HomeLab. The aim is CCNA Wireless and subsequently CCNP Wireless. Of course, I would like to have a go with CCNA Wireless first.
I appreciate your suggestions and recommendations on the setup or related issues for that matter.
Solved! Go to Solution.
01-21-2011 04:25 AM
You're better of going with access points (1140 for example that can be both capwap or IOS) and a 2106 WLC.
Nicolas
01-21-2011 04:25 AM
Nicolas
01-21-2011 12:11 PM
Hi Nicolas,
I will look at the features of the models you mentioned and if I have questions (regarding them), I will put them down on this thread.
01-21-2011 07:16 AM
It all comes down to how much you want spend ? You can get a 4402-12 for under 2k in some cases on ebay.
01-21-2011 12:06 PM
Thanks George,
I think this option is far too wide for the budget. But yes, that is something I may look at in the future.
01-21-2011 12:16 PM
I have a pretty extensive lab and I am always willing to share with other Wireless colleagues..
2 4402-12, ACS, WCS, 1252,1132 etc ... Let me know if you need something to pound on remotely ..
