wireless implementation
m-daja
Visitor
i will need to implement only 5 wireless access points for my company meeting rooms.i have thought to implement Cisco Aironet 1240AG to operate
as an autonomus AP.considering the fact that my catalyst 2950-24 concentrated in one catalyst 6506 does not support POE i will use the power supply
will i encounter any kind of problem if the WLAN controller will not be used
Rob Huffman
Hi Mehmet,
For 5 AP's you don't need the WLC at all. To run these in Autonomous mode will work just fine! For power options you could also use power injectors if there is no A/C outlet near the AP mounting location;
Cisco Aironet Power Injector (AIR-PWRINJ3) Cisco Aironet power injectors use the power supply that is available with Cisco Aironet 1240AG Series access points.
From this good AP1240 Guide
http://www.cisco.com/en/US/products/ps6521/products_qanda_item0900aecd8031c8dc.shtml
Also, don't forget antennas;
Antennas for both 2.4-GHz and 5-GHz radios are available and must be ordered separately. High-gain omnidirectional, narrow-beam directional, diversity, and nondiversity antennas are available for both operating bands.
For more information on antenna options, visit:
http://www.cisco.com/en/US/products/hw/wireless/ps469/index.html
Hope this helps!
Rob
thanks for your reply ROB.
i think to implement Cisco 1130AG series for indoor use in autonomus mode
Rob Huffman
Hi Mehmet,
The 1130 will be an excellent choice as well. We use them in our environment quite successfully 🙂 Make sure to order the IOS version for your rollout;
AIR-AP1131AG-x-K9 Cisco IOS Software
Where x =
A=FCC
C=China
E=ETSI
I=Israel
J=TELEC (Japan)
K=Korea
N=North America (Excluding FCC)
P=Japan2
S=Singapore
T=Taiwan
From this good doc;
http://www.cisco.com/en/US/products/ps6087/products_data_sheet0900aecd801b901c.html
Hope this helps! And best of luck,
Rob
