wireless issue with broadcom lancard
jangkiyoun
hi all
i have issue with broadcom that device(laptop) getting download speed is flapping. other chipset like intel btter than broadcom.
do you have any idea about this issue?
this is spec
controller - 55XX Ver7.3.112.0
ap - 1240
wireless chipset -broadcom bcn4313
thank you
Looks like its your broadcom card trying to figure out the modulation it will be using. There isn't really any configuration changes that you would need to do on the WLC since your data rates is flapping from 19-54.  As long as everything is transperent to the user, there is nothing really wrong.  The download or transfer looks like its fine, so really, no issue if you ask me... I never use the Windows utility to check my signal anyways:)
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
6 Replies 6
Scott Fella
Update your driver and test again.
-Scott
i was update already
i will show you movie clip.
Leo Laohoo
Flapping?  You need to provide more info than this.
Is the wireless SIGNAL going up/down or is the radio chipset going up/down?
would you check that video clip?
i uploaded how it's works.
thank you.
Scott
-Scott
thank you Scott.
i just want make sure about that.
by the way i sent issue broadcom and laptop vender but i couldn't any answer.
i'm also pretty sure that speed don't have meaning for real speed.
