wireless issue
ahmedalshami
Level 3
Level 3
dear
i deployed Wireless access points with Two WISM i found some problem when some WorkStations Use (wireess adapter linksys )some Workstations is droped the signal and come On again this is the report from Controller
g
System Time
Trap
Thu Apr 3 15:07:55 2008
Client Deauthenticated: MACAddress:00:1b:77:2f:78:41 Base Radio MAC:00:0b:85:8e:f0:30 Slot: 1 Reason:Unspecified ReasonCode: 1
Thu Apr 3 15:07:28 2008
Client Deauthenticated: MACAddress:00:1b:77:2f:7a:e7 Base Radio MAC:00:0b:85:8f:0a:50 Slot: 1 Reason:Unspecified ReasonCode: 1
Client Deauthenticated: MACAddress:00:1b:77:2f:74:01 Base Radio MAC:00:0b:85:8f:0a:50 Slot: 1 Reason:Unspecified ReasonCode: 1
Thu Apr 3 15:01:18 2008
Coverage hole cleared for Base Radio MAC: 00:0b:85:8f:0a:50 and slotNo: 1
Thu Apr 3 14:58:23 2008
Client Deauthenticated: MACAddress:00:1b:77:2f:ab:2f Base Radio MAC:00:0b:85:8f:03:40 Slot: 1 Reason:Unspecified ReasonCode: 1
Thu Apr 3 14:58:19 2008
Client Deauthenticated: MACAddress:00:1b:77:05:99:8a Base Radio MAC:00:0b:85:8f:0a:50 Slot: 1 Reason:Unspecified ReasonCode: 1
6
Thu Apr 3 14:57:26 2008
7
Thu Apr 3 14:57:22 2008
8
Thu Apr 3 14:56:29 2008
9
Thu Apr 3 14:56:25 2008
Not applicable
Does other clients in the same vicinity receive good signal strength. If so upgrade the firmware of the adapters that are not working. If other clients are also dropping check the access point coverage in that area. Increase the signal strength if the need be. Also check for interfering sources with the help of softwares like netstumbler which might degrade the signal strength.
