Wireless Issues
spurdhan
Community Member
I have a Cisco Aironet 350 at home and I use DSL to connect to the Internet. I currently have to change my profile everytime I go home as at work I use LEAP. My problem is that if I go in a different room from my Access Point my neighbors connection disconnects my connection and then I have to reconnect again. Even though I have a dedicated profile assigned to my Home Profile even then it keeps changing to the open connection of my Neighbor.
Can you help to solve this problem.
alinn
Hey There,
If your using a 350 card, you can try entering the ip address of your home AP into the Advanced Infrastructure Tab, there is a place for 'Specified Access Point 1-4' This may do the trick.
Aaron
