Wireless LAN Connection Configuration
ja.patrick1080
Community Member
Need Basic Wireless LAN Connection Configuration Example
2 Accepted Solutions
This link provide WLC configuration examples
http://www.cisco.com/c/en/us/support/wireless/5500-series-wireless-controllers/products-configuration-examples-list.html
Refer config guides if you need step by step guide for all features configurations
Rasika
*** Pls rate all useful responses ***
Hey James,
Please go through the below links which can help you on best practices for basic WLC configurations.
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/68005-wlan-connect.html
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/116584-configure-wirelesslan-00.html
6 Replies 6
ja.patrick1080
Community Member
any update
Rasika
Hi Everyone,
I have a scenario in which WLC 2504 is connected to Core switch 4507R+E.and access switches are connected to Core switch as well. In these access switches Access points AIR-CAP702I-A-K9.
My question is as follows:
I want to use vlan 104 for office employes with SSID OFFICE-EMPLOYES
I want to use vlan 103 for guest with SSID Office-Guests
Below is what i have configured on core switch
(config)#interface xx
(config)#description xxx
(config)#switchport mode trunk
(config)#switchport trunk allowed vlan 103,104
Below is what i have configured on access switches
(config)#swithcport mode access
(config)#swithcport access vlan 104
If i am configuring trunk port on access switches and allowing both vlan's 103 & 104 access points are not joining controller.
Right now management IP is from vlan 104 and all access points and clients are getting ip from 104 vlan.
What shall i do in this scenario.I want to use segregate the guest and office employe traffic.
It would be great if any one can help me.
Moin Ilyas
Level 8
Level 8
http://www.cisco.com/c/en/us/tech/wireless-2f-mobility/wireless-lan-wlan/tech-configuration-examples-list.html
Hope that helps.
gohussai
Level 8
Level 8
Check the link below ,example with Cisco best practice.
http://www.cisco.com/c/en/us/td/docs/wireless/technology/wlc/82463-wlc-config-best-practice.html
Hey James,
