Wireless Lan Controller 4402-12K9 Upgrade to 25 APs
I have a 4402-12-k9 controller and I need to upgrade to 25 APs
Can I buy a 12 or 25 license upgrade to this controller?
I heard that is not possible to do that, there is a Cisco paper about it.
7 Replies 7
Scott Fella
I believe the smallest amount for an addr license is 25. So you would end up with 37 AP count.
-Scott
I just read this discussion
https://supportforums.cisco.com/thread/329260
But is a post from 2008. Is still true?
Yes... The 4400's need to be ordered with the ap count required. The 5508's you can add license for. So the info I gave you earlier was for the 5508, 2504, WiSM2.
-Scott
Leo Laohoo
You cannot upgrade the license of the 4400.
No... I corrected myself on the other post:)
-Scott
I was just agreeing with your correction.
Haha... I should of just edited the post but was lazy.
-Scott
