Wireless Lan Controller 4402 SFP interface
Mozz
Frequent Visitor
Frequent Visitor
is the GLC-T SFP installed on a WLC 4402 capable to negotiate 10/100? Documentation says that is 1000BaseT but command reference has no posibility to set autonegotiation or configure speed.
sushilk
Level 5
Level 5
Since this is a 1000BaseT SFP it supports only 1000Mbps. It will not support 10 or 100Mbps.
This is the reason you are not getting autonegotiate and speed configuration options.
Sushil
