Wireless LAN controller 4402
r.vanschendel
Is it possible to config only 1 GB connection to 4402 LAN controller. Or must I use both Gb connectors ?
Because I have only 1 Gb port free on my switch.
ankbhasi
Hi Rene,
You can very well use only one gig port to connect to the switch. 2 ports can be used if you want to have por tchannel on switch and you want your controller to work with LAG.
But you can simply connect 1 port on switch to the controller and while configuring manamenet and ap-manager interface bind them to one physical port whichever you are using.
Ankur
*Pls rate all helpfull post
ankbhasi
Hi Rene,
Ankur
