Wireless Lan Controller 4404 exclusion setting
lbunnell
Community Member
I have a Cisco 4404 wireless lan controller managing about 85 AP's.
The wireless side is setup for a private wlan and a public wlan.  On the public side, users are directed to a captive-portal agreement page before they can get on the internet.  My question is if there is a way for a single client, specified by either mac address or static IP , can be connected to this wlan without being prompted for the agreement page?  I would like to setup a wireless printer for guests connected to this public side.
Amjad Abdullah
That is unfortunately not possible.
What you can do is to creat a new ssid (possibly hidden one) on same guest vlan and connect the printer to it.
Rating useful replies is more useful than saying "Thank you"
Saravanan Lakshmanan
you can use 'webauth on mac failure' option to achieve this. It enables L3 - web authentication on L2 - MAC filter failures.
#Configure printer mac address on mac filter for that guest wlan.
#On wlan - security>> L2>> Enable 'MAC filtering'.
#On wlan - security>> L3>> select 'On MAC Filter failure'.
