09-18-2012 03:44 PM - edited 07-03-2021 10:41 PM
I would like to know the following about Cisco Unified Wireless Network :
It's possible the integration of a Wireless LAN Controller like as 2504 and a Cisco SMB switch like as SG300-28 - SRW2024-K9
for proper communication with LWAP like as AIR-LAP1242AG ?
I have some experience with the installation of Wireless LAN Controller and Cisco Catalyst 2960 Series / 3560x Series , but I've
never done the installation with Cisco SMB .
Regards .
Solved! Go to Solution.
09-18-2012 06:16 PM
If you plan on having more than one vlan, then you need to trunk, or else you just set the management vlan to 0 "untagged" and it will work.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
09-18-2012 05:20 PM
Most switches will work. I have even tested it with some hubs. Just make sure you have enough power to power up the AP's depending on how many you will put on the switch.
09-18-2012 06:14 PM
I remember that the only requirement is that the device must be support 802.1Q Trunk Port .While this is configurable, should be work's .
What do you think about it ? .
Regards.
09-18-2012 06:16 PM
Scott
