wireless lan controller, enabling LAG
carl_townshend
Hi all
I have used more than 47 ap's on my 4402, and now it wont add any more, If I enable LAG it comes up with a warning saying it will delete all my current interfaces, is this true?? or if I enable LAG should it still work as before??
cheers
Stephen Rodriguez
Carl,
    Enabling LAG does not delete the interfaces.  So if you enable LAG and reboot, you should be fine.  Alternately, you could configure another AP-Manager and link it to the other port.
Cheers,
Steve
If  this helps you and/or answers your question please mark the question as "answered" and/or rate it, so other users can easily find it.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Stephen Rodriguez
Carl,
Cheers,
Steve
HTH,
Steve
George Stefanick
carl,
Keep in mind you will need to etherchannel your switch if you use LAG and keep all the connections on the same switch.
