Wireless lan controller license
pnrajamca
Community Member
i need Wireless controller for 44 access points.
i seen some controllers at amazon.com model : AIR-CT2504-50-K9 price 2000USD. this device license included or i need license separately. please any one inform
jtier
Level 3
Level 3
I wouldn't recommend buying Cisco hardware from Amazon. Buy it from an authorized reseller/Cisco partner.
The AIR-CT2504-50-K9  comes with 50 licenses for Access points.
Depending on when it was manufactured you will likely not have an version of AIR-OS that will run the 3000 series access points, and being that you mentioned using a other-vendor, you will not get any kind of agreement to download or use support.
So, keep in mind that while 50 AP can be joined to that model IOS versions matter, as well as support agreements.
Buyer beware.
Leo Laohoo
Whao! That's one very, very expensive piece of OLD equipment.
I'd be looking at the 3504 instead.
dave.clark
Frequent Visitor
Frequent Visitor
Model: AIR-CT2504-50-K9 Cisco 2500 Series Wireless Controller
Detail: Cisco 2500 Controller AIR-CT2504-50-K9 2504 Wireless Controller
with 50 AP Licenses So that will cover you for all your needs, the MAX
licence this controller supports is 75.
Good Luck
