Wireless lan controller LLD Documents
waqas sardar
Level 7
Level 7
Hi Team,
Any one can share the LLD Documents for the Wireless lan controller Implementation.
Moin Ilyas
Level 8
Level 8
Not sure what exactly would you require for an LLD, please refer to the following link for Wireless LAN Controller Best Practices.
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/82463-wlc-config-best-practice.html
Hope it helps.
