Wireless LAN Controller terms
kian_hong2000
Level 3
Level 3
What is the purpose and reason for using management, AP-manager, virtual, and service-port interface?
My bad... I mean WLC
In band is telnet, ssh to the management ip. out of band is when the port has no real connection to your network. That is why the ip address of the service port is an ip address that is not part of your network nor should it be routable in your network. In case you loos connection to the management and you don't know the commands for the cli, you can connect to the service port and use the gui.
-Scott
Scott Fella
Management is for management of the lwc
AP-Manager is for communication between the ap and the WLC
Virtual is for Layer 3 Security and Mobility managers to use
Service Port is for out of band management
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a0080665cdf.shtml
-Scott
I still have some doubts.
1) What is twc stand for? Is it Wireless Control System?
2) What is the correct meaning of In-band and Out-Band management? Can i say Out-band is for telnet, ssh etc and In-band is for console?
3) Why we need Service port since we already have Management?
-Scott
