Wireless Lan Controller Web Authentication Bundle
amalitol81
Level 3
Level 3
Guys,
I have checked and it seems the WLC model 3504 does not have a Web Authentication bundle to download.
What can I do if I would like the customize my Web-auth page for Web users, Could I use others "Wireless Lan Controller Web Authentication Bundles"?
For example I could download Wireless Lan Controller Web Authentication Bundle for WLC models: 2106, 2125, 2504, 5508, 8510, 8540.
Thank you guys,
Guys I have received the following answer from the Cisco TAC
"I understand that you are not seeing the Web Auth bundle for a customize internal portal on the download section for WLC 3504. You can go ahead and download the bundle from another WLC page.
This bundle holds the same HTTP functions needed for the WLCs to gather the needed information, so there should not be any problem for you to download the bundle from other WLC."
So, it seems that the "Wireless Lan Controller Web Authentication Bundle" is the same for all the WLCs
Hi Amalitol,
I have checked for the same but not getting anything related to that as of now. Log a case with TAC for confirmation.
Sathiyanarayanan Ravindran
Please rate the post and accept as solution, if my response satisfied your question:)
Thank you,
That would be the second part of this story.
