Wireless LAN Management
m-briody
Community Member
Members,
Any suggestions as to which is the best WLAN management application to use for AP 1200s?
Our WLAN Network is small at the moment but could grow a lot bigger.
I would like to try Cisco Wireless LAN solution Engine, but unfortunately they do not make available an evaluation copy.
So, any ideas?
Martin.
pvengalam
Community Member
Martin,
I am aware of a solution that effeciently manages, moitors and helps in mass-configuration of small and medium sized WLAN infrastructure including all Cisco Accesspoints, Switches and routers.
If you are interested send me an e-mail at [email protected]. I can refer you to the appropriate contact. They do provide an evaluation copy.
Praveen V.
f49713
Community Member
"but could grow a lot bigger!";
then Cisco Wireless LAN Solution Engine is the right Solution for sure. (near 5000 USD)
An evaluation copy is impossible because you need a "special" cisco hardware. (Cisco Unix "Server", 1HE). Try to get a testing equipment if possible.
hardware:WLSE 1130
software: Version 2.5
Arno
