Wireless LAP as repeater
descalante2007
Level 3
Level 3
Is it possible to configure an AIR-LAP1242G as repeater? I can't find an option in the Wireless Controller 2106.
Rob Huffman
Hi Daniel,
This configuration is not supported in Lightweight Mode;
Q. I have an existing wireless network (autonomous APs) with an access-point that is configured as a repeater. This network is to be migrated to a LWAPP wireless network. Can I use the LWAPP APs as repeaters?
A. LWAPP APs must join a controller, and they do not support a repeater mode since they all have to have some connectivity to the controller first. Cisco autonomous APs can be configured as repeaters, but due to the reduction in effective bandwidth available to end clients, repeaters are not the most highly recommended configuration. While any Cisco Aironet AP or LAP model can be used in either LWAPP or autonomous mode, in order to make that change, a software reimage is required. This is particularly complex when it goes from autonomous to LWAPP, so directly, no, an AIR-LAP1232AG-A-K9 does not natively support the repeater mode. It could be loaded with autonomous software and be made to support repeater mode, but that would involve a software change and a separate configuration.
From this good Q&A doc;
http://www.cisco.com/en/US/products/hw/wireless/ps430/products_qanda_item09186a00806a4da3.shtml
Hope this helps!
Rob
