Wireless Lobby Admin Viewing Local Users
joe.ho
Level 3
Level 3
I am running version 8.0.110.11 on the WLC. There are multiple Lobby Admin accounts. Each one of them have rights to create guest account. Is there a way to have each Lobby Admin only see the specific guest accounts they have created?
For example Lobby adminA created guest1 and guest2, Lobby adminB created guest3 and guest4. When Lobby adminA login it will only display guest1 and guest2 but not all four.
Thank you for your respond.
abwahid
Level 9
Level 9
yes you can create lobby admin accounts in this way.
please refer the below deployment guide.
http://www.cisco.com/c/en/us/td/docs/wireless/technology/guest_access/technical/reference/4-1/GAccess_41.html
Freerk Terpstra
Level 11
Level 11
This is not possible on the WLC. Every lobbyadmin will see all of the local net user accounts which are created as a guest user.
