WiFi Clients Unstables
Dear
We have problems in my wifi, I have WLC 2504 and 5 APs, however clients are experimenting flapping in the conexion, I verified with a client, and this one is jumping from one AP to other one, also I have some debug, you can see that in the attachment.
Thanks for your help.
10 Replies 10
Milos Megis
Level 3
Level 3
Do you have enabled client load balancing ?
Menu: WLAN --> Choose your WLAN --> Advanced --> Client load balancing
If it is enabled then try to disable it
Dear Milos
Client load balancing and band select are disabled.
Then I don´t know what can cause this,
but if you have AP with cleanAir chip, you can switch it into SE expert mode and perform some spectrum analyzes, if it is congested by some external device - microwave oven, or IP camera can also take whole channel.
Stephen Rodriguez
what NIC and driver version are the clients using?
Keep in mind that windows update does not update the wireless drivers.
HTH,
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Dear Stephen,
There is a MIX of clients, Lenovo, Dell and HP, but everyone has same problem.
Mario
But what is the wireless NIC. Is there a common chipset?
Intel, Broadcom etc
HTH,
Steve
HTH,
Steve
Dear Steve
The most common chipset is Intel.  What is your recomendation whit it?
my recommendation would be to grab the latest drivers, and build an MSI package that you can push to your clients with a GPO, and install the latest drivers.
HTH,
Steve
HTH,
Steve
Drivers were updated, but still the same problem. What about debug logs??  Do you know if is a correct behavior?
Dear all
pls comments about debug attached, also i would like share that there is a mix of APs 1242AG and 1602E, i dont know if exists a know problem about that.  Pls thanks for your help.
