Wireless mDNS Bridging CLI command
absuizo14
Level 3
Level 3
May i know what is the cli command to enable this?
I tried enabling it in the GUI but when i looked at the difference upon saving the config there were no difference so I'm suspecting that this is connected to the issue we are experiencing right now where in the mdns packets from the server are not reaching the chromecasts.
Mark Elsen
 - FYI : https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/17-1/config-guide/b_wl_17_11_cg/mdns.html#id_97897
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Rich R
As I've advised previously do not try to do chromecast with mdns bridging.  You'll need a chromecast proxy which is directly connected to the chromecast subnet and the user subnet to make this work half reliably.  Ethernet connected chromecast units with chromecast proxy for wireless users (proxy still needs to be directly connected to the user subnet) is the most reliable solution for chromecast.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
Yes there is a proxy server for that purpose. mDNS gateway on the WLC is not ideal because the wireless users are able to cast to all the chromecasts in the hotel and that would be problematic. imagine casting some obscene videos to the other rooms. here is the diagram of this setup.
