10-02-2014 12:55 PM - edited 07-05-2021 01:38 AM
I have created a switch peer group between two 3850's. Should I have to create all the WLAN's and ap-groups on the agent as well as the controller. This seems wrong. I would assume all setup would be done on the mobility controller and pushed to the agent but maybe I'm wrong.
Mobility Controller Summary:
Mobility Role : Mobility Controller
Mobility Protocol Port : 16666
Mobility Group Name : wireless
Mobility Oracle IP Address : 0.0.0.0
DTLS Mode : Enabled
Mobility Domain ID for 802.11r : 0x89f
Mobility Keepalive Interval : 10
Mobility Keepalive Count : 3
Mobility Control Message DSCP Value : 48
Mobility Domain Member Count : 1
Link Status is Control Link Status : Data Link Status
Controllers configured in the Mobility Domain:
IP Public IP Group Name Multicast IP Link Status
10.120.136.5 - coop-refinery-wireless 0.0.0.0 UP : UP
Switch Peer Group Name : tester
Switch Peer Group Member Count : 1
Bridge Domain ID : 0
Multicast IP Address : 0.0.0.0
IP Public IP Link Status
10.120.140.5 10.120.140.5 UP : UP
Mobility Agent Summary:
Mobility Role : Mobility Agent
Mobility Switch Peer Group Name : tester
DTLS Mode : Enabled
Switch Peer Group Members Configured : 1
The status of Mobility Controller:
10.120.136.5 10.120.136.5 UP : UP
Switch Peer Group members:
IP Public IP Data Link Status
Dallas
Solved! Go to Solution.
10-06-2014 01:50 AM
Hi Dallas,
As of today you do not have the luxury of creating all WLAN/AP group config on your MC & then it will push it for MA.
So you have to configure all your MA identically for WLAN/AP group etc.
Rasika
**** Pls rate all useful responses ****
10-06-2014 04:08 AM
Mobility Agent is a dedicated controller at the end of the day. It just depends on the Mobility controller for few of its requirements like Mobility. For everything else , you should consider it as a normal controller and configure individually as you do on CUWN WLCs.
Dhiresh
10-06-2014 01:50 AM
Hi Dallas,
Rasika
10-06-2014 06:08 AM
Thank you both for the replies.
10-06-2014 04:08 AM
Dhiresh
